elgrillo
El Grillo
Hello guys, I have a Marantz 250 with serial number #2109. I have a few dilemmas.
I need to replace transistors q507 and q508, I already have 2n5415 (q507) and 2n3440 (q508) . But this are replacements from the bulletin M-250-3 where they specify "for serial numbers ABOVE 6549.
Can I still use them or this is not recommended and I need to find 2n5680 and 2n5682 ?
My second dilema , In the schematics of the original 250 (first schematics) there is no diode under Q510, and in the addendum 1 there is a diode under Q510. Should I need to "upgrade it' and put a diode. This is a germanium diode as far as I know.
Just for more info the amp at this moment has this:
Q510 and Q511 have Toshiba's 2sc783 and 2sa483
As output transistors there are MJ21193G & MJ21194G.
Thanks in advanced.
Gonzalo.
Thanks in advanced.
Gonzalo.
