Hi everyone! I recently found a great deal on an MC250 poweramp with an MX110z preamp. My initial plan was to restore the MX110z first but unfortunately it was very badly damaged in shipping (broken glass, broken tip of the power knob, broken panloc button, etc) so I've decided to start with the MC250 first. Both power on and sound decent but there is a low level hum present in the MX110 that I will tackle by modifying some of the wiring after updating the components, but for now we start with the power amp.
This MC250 is one of the earliest versions based on the schematic I found that matches the circuitry of my unit. Fortunately, there are not many parts and this should be a fairly easy restoration. There are a few color coded and striped capacitors who's value im not sure of yet but will be pulling up the schematic and using that figure out the values if no one here knows off hand.
My plan for this restoration is to replace all 4 of the large can capacitors on top along with all of the electrolytic, mylar, and disc capacitors inside. I also plan on checking most of the resistors and replacing any that are off value. How do people feel about using different types of resistors like low noise metal films on this unit? On the 2 9600uf cans on top, does anyone have any recommendations for drop in replacements? I see people recommend increasing the capacitance, but how high can we safely go? One guy on Ebay recommends using 18000uf chemi-con brand cans that fit without modifying the chassis. Also if all of the voltages check out and the diodes test good do you guys recommend changing those still? Any troublesome transistors that should go?
It will be a few weeks before I get all of the parts in and have time to work on the unit but I will be posting a parts list along with the replacement parts I will be using in the meantime. If anyone has any recommendations or ideas for this restoration I am all ears. I have attached pictures of my unit along with the schematic for this particular piece.
