First off, I would like to thank AK Member Santa for offering these rigs up on Barter Town. I've been looking for an affordable pair for nearly 2 years, it's been a long haul. I was holding out for a ported version of either the W60, W70 or the W90 in a condition where I wasn't paying a premium. And brother or sister, when you see a deal online? You have to move within maybe 4 minutes of going up, or you're gosh out of luck. Thankfully BT moves a tad slower than the other online venues.
Santa lives a solid 85 miles round trip from me, but it's an easy drive on the weekends. I got there and back it what seems only moment or nine.
I had no real idea as to the physical condition of them, only knew there was 1 bad tweeter. As it turns out, he says it's actually okay. But the foam has long since rotted away. There's no spider holding the cone in on these older Super 3's, the cone will fall out if not careful!
Does anyone have a source for getting these older tweeters refoamed/inspected?
The lacquer finish has severe age issues, milky/hazy and makes the color of the wood off. There are plenty of scratches, but the edges and corners seem to be in decent enough condition. Someone has had their hand on and in these. The top of one of the enclosures has already been sanded for about 3 to 4 minutes. Thankfully, they stopped! No real damage, but it forces me to refinish these sooner rather than later.
The bad tweeter was already out of the enclosure when I picked them up. The wires for the tweeter are cut, and there's 1 missing wire going from the pot to the strip that goes to the mid and woofer. The strip on the back of the tweeter box is broken off and blowing around inside the enclosure. But the other enclosure is completely intact and I can just copy what needs to be done from there.
Someone has replaced the batting with something modern. I don't know if this is an issue, I wish I had the original.
THERE'S NO SAND FILLED BACK. Not sure what that's all about. The 1" walnut veneered back with brass screws all looks original.
Santa mentioned that he thought there were serial #266 or something along those lines. I can't find any reference to serial numbers on the enclosure. The drivers are marked 1961.
I will remove the rest of the drivers to inspect the surrounds, just to make sure everything is as it should be. The other tweeter will have to be removed. If it still "works", it won't be for long.
These W70's are going to require some effort to bring them back to life. But compared to the Altec's, these are going to be a BREEZE.
Biggles
