KlipschFan61
Smooth Jazzer
Again folks, pinging properly, there is no risk to your having to pay for the item...
Two words come to mind here...
Bid retraction.
Let's say the auction stands at $325, the bid increment is $5 and the current high bidder's limit is $345.67.
You: $330
Proxy: $335
You: $340
Proxy: $345
You: $350 Oops...now you're the current high bid
You know only that the previous high bidder's limit was somewhere from $345.00 to 349.99, and you have outbid that...
Am I missing something?
... that way u have to outbid the highest bid or his proxy. a tie goes to the earliest bidder.
I see. Thanks for the explanation.Yep. Proxy bidder bids $345, you bid $350, your bid is rejected because it is below $350.67, which is the minimum $5 increment above proxy bidder's $345.67. You now know that proxy bidder's max is between $345 and $350.
Proxy bidder only has to tie your bid to remain high bidder, but you must beat his proxy by the increment.
Why tip your hand?
I just watch them and wait.........
BTW, bid wacky numbers. like $27.66, not $25.00, $103.62, not $100.00, and you'll beat out the Joneses who stick to the even price points quite often. :yes:
You're right, unless you want punish another bidder for consistently bidding on all of a particular item and not reserving at least one item for everyone else to bid on. :screwy:Again, as a buyer, there is no advantage to finding out what another's max bid is. Knowing that should have no effect on what you are willing to pay.
The fact that pinging is a waste of time supercedes the ethicality.
There is no advantage; in fact, there is a distinct disadvantage, to artificially driving up the price of the auction.
Snipe.
...Pinging works because the proxy high bid is different than the rest of the bids and, as a result, gives warning before you top the proxy max...
Again folks, pinging properly, there is no risk to your having to pay for the item, since you are able to determine when your so called "bids" are getting close to the max proxy bid of the current high bidder. The unfortunate by-product is that the price gets run up tot he proxy max by a person who has no intention of really buying the product, or bidding to obtain it...just to either run up the price, or to obtain "intelligence". That is just wrong.
Y'all go ahead, if you wish, but instant karma is a mutha. What goes around does get on ya...being translated means, you will reap what you sow, later than you sow, and greater than you sow.
I'm out.
Rich P
One thing that you folks seem to be forgetting about the other bidder who has a max bid entered and whose bid is being raised by proxy is this. The proxy bid is raised by specified amounts that are clearly defined by eBay.
The "pinger" is NOT restricted to raise HIS bid by specified amount.
That's why it works...
...Yes, it is true that "sniping" is about the only way to win a desireable item on the bay these days other than placing a "jumbo bid", but that's the way it is...
...Also, I have found that if I read all the previous posts in a particular thread, I am better prepared to add my own post.
Did you miss the part about the "jumbo bid" being the best way to beat a snipe?
... But I would have paid the $1600 if it ended there...
...Abraham Lincoln : " tis better to be silent and thought a fool than speak and remove all doubt".
