they don't look terribly complicated so it should be possible to reverse engineer one.
The power amps look like they were once stereo amps, but now converted to mono use? Guessing that based on the layout and the extra holes that seem to match the output transformer and speaker jacks. There are a couple of ways to make that happen, and I'm sort of curious what they did here. In stock form, my guess is these are basically a Mullard style front end. One triode as a voltage amp, a pair for a long-tail pair inverter, then the output tubes. These look like 6BQ5 / EL84 types. One plate of each tube to the transformer, no funny business.
It looks to me that the two plates on each side are jumped together to form a parallel set of outputs. That has to mean the front end was re-worked. If you just jumped a pair of plates together on a push-pull set, the signals would cancel and you'd get a fat lot of nothing for output. The grids would also have to be paralleled to get the same signal. Just looking at the component layout here, what I think they must have done is pulled one coupling cap from each inverter, so each side has a working LTP, but only one output on each is used. There must be a jumper underneath tying the grids together on each side so this functions. IMO this is an inefficient way of doing it, but its probably the least invasive way of doing it with a circuit board.
The trick here is that parallel output tubes want half the transformer load. Typical EL84/6bq5 load is about 8k plate to plate. Parallel wants about 4k. If these output transformers have a 16 and an 8 ohm tap, no problem. Connect an 8 ohm load to the 16 ohm tap, you get 4k of load at the plates. If its just an 8 ohm tap though, you're still working into an 8k load so those parallel outputs are honestly not going to do much for you. Maybe it will deliver marginally more power but probably not enough to justify the work to get it.
Not sure whats up with the rat nest in the preamp. Volume control is missing and wires are hanging. Have to trace that out to figure out where its even supposed to go.
