This took a WHILE, to say a least. The two Edison 24 amp´s have been resting on my shelf since last mail. Decided to finish them, but after recap/ rewiring/ cleaning, one amp is distorting heavily when playing anything over low/ mid volume (the preamp is still in parts, so not connected here). Tried the other amp, not restored but fixed, same tubes, and this does not distort. This is not the typical tube overdrive, more like a transistor fuzz pedal/ crackling distortion.I´ve gone through every solder point, and both amps are wired identically.
Replaced on one amp:
-new rectifier bridge
-new electrolytics (same value)
-new film caps (2 0.47uF and 2 0.1uF. Was Ero, replaced with Clarity Cap)
-new 33ohm/ 5w resistor in PSU
-new speaker and rca connectors
-new speaker and signal wires.
As for the two black wires from the PSU caps, these where put underneath the PCB on the restored amp.
2 pics of restored amp, 2 pics of non restored.
Any thoughts?
Thanks in advance!
