keithpgdrb
Hey all, I have a "mostly" functioning unit. "mostly", meaning that one day it seemed to be working fine, and the next, it did not.
I figured the best thing would be to replace the parts that are suggested over at the Tone-lizard's site. My questions relate to exactly which parts I should be ordering.
They suggest replacing selenium diodes cr1 and cr2. first, I need to figure out what and where they are, then order a replacement part. The replacement parts list in the manual list cr1 as rectifier, 50ma.. cr2 is listed as rectifier, diode.
so what do I order?
next, lizards suggest replacing filter capacitors C1 and C2. They suggest using 22uF/150VDC for C1, and a 22uF/25VDC for C2.
again, what do I order, because there are many kinds over at parts express.
lastly, for some reason, the meter needle wont go down to 0. It used to, now it wont. I've tried to adjust it with the adjustment screw on the front, but to no avail. any suggestions?
Let me know if I need to snap some pics for help. Thanks a bunch guys.
so what do I order?
