Eico 667 Restore
Well, there you have it.
Now I reread the thread and I see ferninando ID'd that back in post #9, LOL. I missed that previously. So looking at that rectifier the red wire goes all the way back to the selector switch as shown in your pic #3 of post #7. So you should be able to disconnect the black and red wires and put a new diode across from where the black wire connects to the cap & resistor and over to where the red wire connected to the selector switch (looks to be two contacts from the 5W 3K Ohm resistor).
so here is where the black wire connects.
and the other picture, what is this thing? is it a diode of sorts?
I'm still a bit confused about the black square being a diode. and the little glass thing being a diode. how can I be replacing these two different parts with the same thing?
To the resistor? Does the black wire go from that to the black box?
The left pic looks like a resistor, similar to the red one in the second pic.
The right hand pic looks like a small signal diode. I have no idea why one would be in a tube tester, unless it really is a rectifier diode and I just don't recognize it, or somebody made an incorrect substitution.
Now you're confusing me. In post #20 you said the black wire goes to the big black box and in post #22 you're showing a black wire to a black resistor. My previous response on the black box was before you posted the pics. I believe the black wire from the cap goes to the black box which is probably a power selenium (sometimes they get large & boxy); I am going to assume that you're other question is asking what that other black thing is, which is a resistor. Please clarify or are we getting the pics crossed?
Yep, that's the other diode we ID'd earlier in the thread.
sorry to confuse everyone.
I followed the black wire from the picture in post #17. That black wire went to the little black box with the red and black wires going into it. second picture in post #22.
so, in picture from post #22, I see, a black cap, a transparent glass diode, and the black box, which is also a diode. This is what I understand so far.
There are supposed to be two diodes in this machine. are these they?
I'm sorry, I dont know how to get duplicate pictures into a post.
They would seem to be the ones - the little glass diode and the big boxy one. :yes:
FYI, the attached shows a 667 with the diode connecting from the resistor to the selector switch if you wanted to put the diode local to the cap instead of over where the big black one currently is.
thanks for all the help so far. sorry I confused everyone. I'll start off with replacing the diodes, test it, then try the caps.
One thing that still puzzles me, I can not get the meter needle to go to zero (left). The unit is off, unplugged, and it still sits high. I've tried to adjust the screw on the front, but it doesnt go far enough. I am reluctant to open it up. but I'll deal with these diodes and caps first. I'll throw up a video to show you guys what I'm talking about as well. I thought of a way to be high tech.
if I can figure out the needle thing, I will have a great (functioning) tester.
The line adjust is also off from your video. You may need to go through the maintenance calibration procedure to allow correct scale deflection.
yeah, I'll re calibrate all that after I change out these parts. It worked ok at one point. Its odd, the unit was actually working fine, then one day, the needle wouldnt go all the way down. I wasnt even messing with it when it happened. It would be great if changing the parts fixes it, but I doubt it, because it sits high when the unit is off and unplugged.
Another question. On the diodes. On the glass diode, which end is the positive? There are colored bands on one end, and an "E" on the other. I seem to recal that e means ground. But I could be very wrong. On the black one, same question. Although I suppose the red wire is positive and the black is negitive.
Lastly. On my new diodes, there is a silver stripe on one end. That is the negitive side, right?
Last hurdle. when I followed the red wire from the diode a bit closer, I see that it connects to the 50 on the filiment dial. when I check the schematic, this is right. the problem is that desoldering the red wire from this nest would be a huge pain. and I very well may do more damage than good.
my questions are these.
1. could I leave the red wire soldered to the 50 point, and just solder the diode to the wire itself? in that situation, I would have capacitor to diode negitive, diode positive to red wire, red wire to 50 filiment point? I would basically just be adding a length of wire to save myself some soldering woes.
2. just to make sure again. if the black wire is currently connected to the capacitor, that is where I should connect the Negitive (banded) end of the diode, correct?
Seriously, I could never have attempted this without you guys. I really hope it still works after all this.
The pictures below show a close up of the burried red wire, and a shot a little further back to show the proximity of where I am. the capacitor is on the other side of the blue pot.
