Are those 7189A relabeled GE or Sylvania?Bought these NOS 7189s last summer for my Scott 222c (the 7868 are for my Fisher 400). Haven’t tried them out as the 6P14P-EB in there now are doing fine.View attachment 2942976
Important for reducing output stage hum, too. I like hum pots in the output of p-p amps.Whatever brands of EL84 used, using matched tubes is important in push-pull amps. Reasonable matching at typical usage conditions needs a lot of tubes in order to get matched pairs.
Get those smokey mullards. So good.
But it's fun looking at this thread. There are tons of great sounding el84/6bq5's.
Thats probably why I like the So tek EL84M's then.As far as I know EH EL84 are relabeled 6P14P tubes. They are good tubes.
The Sovtek EL84M are built to the old 6P14P-EV mil specs. Solid tubes.
Mullards ( UK ) had a round hole on the plates.View attachment 2943006
They say Mullard, International, Made in Great Britain
These tubes remind me of Mullards the way they get those blotchy spots on the glass.As far as I know, the 6P14P-P have been constant vibration tested for industrial use --- 3000 hours life.
The 6P14P-ER have the longest mean time between failure rate of 10,000 hours.
Gotta check for Philips/Mullard etched codes.Mullards ( UK ) had a round hole on the plates.
Yours don't seem to be made in UK, as they have seams on top of the glass, and only Mullard made in UK tubes had the seams.
My guess is that they are probably Japanese (Matsushita) , PHILIPS , EI, or BEL (India).
Yes, BEL India had the V , PHILIPS Heerlen had the Δ (delta) , EI had a dot in a circle (I think).Gotta check for Philips/Mullard etched codes.
I know India and Japan did have country codes. V = India. N, 5, 7 for Matsushita, Toshiba, and Hitachi.
I have a quad of these. Really great tubes.There are these Siemens-Halske E84L/7320 tubes...
Some of the very best tubes, in my tilted opinion.I have a quad of these. Really great tubes.
Now that I think about it, I've only seen those blue and white IEC International Servicemaster boxes stamped 7189A. They are Mullard (UK) made, but not true 7189A (with the internal pin differences and uprated plate voltages).
