This is my first attemp at an amplifier build. I plan on using the Skunkie Design schematic with some minor tweaks. I am finishing up the chassis but am concerned I did not leave enough room between the output tubes and the transformers. There is only one inch. If I ever went with KT77, it would be a no go.
So should I just stop and and start a new chassis? If so, what would be a more comfortable distance to use EL34 or KT77 valves. Also, please voice and other concerns such as the rectifier valve/choke layout.
PS: I am waiting on the PT to arrive thus not on the chassis.
Thanks in advance.
As suggested by an esteemed member, herewith are the schematics:
Output transformers are ISO Tango Model FC-12S:
Thanks in advance.
