I finally got around to trying out a quad of EL34's in my KT120 amp. (Remember when I built my amp, I wired pin 1 to pin 8 (suppressor grid to cathode), so that I could do this).
I ended up biasing the EL34's at 50% of their max plate dissipation, which gives these DC operating conditions:
Queiscent current draw per tube: 25 mA
Plate voltage: 500V
Negative bias voltage: -48 volts
(Remember since I'm using a High Voltage regulator, I still get exactly 400V to the first and second stage audio amps so no rework needed there.
Max power output is 50 Watts/channel with 0.84V RMS input sensitivity to drive the output stage to full power. (Remember I'm using the Triode Electronics version of the Dynaco A431: 4300 Primary to 8 Secondary).
The 10 kHz square wave at 1 watt output shows about double the initial overshoot of what I finally settled on for the KT120s, which means the amp should start its roll off at high frequencies a bit higher in the frequency spectrum, but it also means they will probably sound brighter or more lit up than the KT120s.
I'm using the New Sensor Mullard EL34 reissue. These tubes sound pretty good, but as expected, the amp does indeed sound more lit up with the EL34s. The KT120 is a really mellow tube which I enjoy immensely, with a very controlled presentation top to bottom and somewhat rolled off highs.
Conversely these Mullard EL34 reissues are brighter (but most of this I expect is my amp, not the tube itself) and a bit hashier in the high registers. Midrange, especially vocals both male and female, are no better in my opinion than the KT120s. Bass is a little muddier with the EL34s.
Nice tubes overall these Mullard reissues, but I do prefer the KT120s. I need to live with these EL34s now for a few weeks to make final judgement.
I am surprised I'm getting 50W/channel out of these little guys and in ultralinear mode no less (at 33% taps with the A431 OPT).
By the way, it was a real pain in the butt to get the EL34s biased correctly. I didn't want to red plate them, so I had to bring the amp to my work bench, flip it over, take the KT120's out, turn the amp on, set the bias to where I thought it would be, then put the El34s in and iterate until i got them were I wanted. Now that I know...I can go much quicker next time I swap.
Plate voltage: 500V
