Okay guitbanger,
Tonight I tube rolled SED Winged C EL34s vs. Tung Sol KT120s. I started by biasing the EL34s at 50 mA (100% of plate dissipation), and the KT120's at 50 mA (40% of plate dissipation) and then later at 80 mA and then 100 mA (70% of plate dissipation).
For my test track I used Janis Ian Breaking Silence, Analog Productions 200g LP, track 4 on side 1: "What about love." My front end is a VPI Aries with JMW 10 tonearm and Grado Reference Sonata Moving Magnet cartridge into a Jolida JD9 II phono preamp. All I've done to the JD9 is upgrade the output caps to Auracaps 1.0 uF. Everything else is stock. Out of the phono preamp the signal goes directly to my power amp. I have a 100K Alps Blue Velvet logarithmic pot for volume control right on the chassis of the power amp. My speakers are Vandersteen Quatros.
First I gotta say the Winged C's sound awfully good. I do think they sound better than the Mullard EL34 new issues. The Winged C's have a really nice midrange, are slightly more forward in the midrange than the KT120s and are just a bit warmer. Highs are very nice, and top to bottom, the sound is better than the KT120s at 50 mA bias.
The KT120s biased at 50 mA just do not sound as good! At 50 mA, the KT120s are brighter, harsher, cooler in the midrange, and bass is more sloppy. So overall at 50 mA, the clear winner are the Winged C EL34s.
But..the story's not over there. At 80 to 100 mA bias on the KT120s (I couldn't tell a difference), the KT120s just sing. They are more controlled top to bottom. They are just a bit cooler in the midrange still, and are not as forward as the EL34s. Bass is very tight (beating the Winged Cs hands down). I can hear just a bit more detail with the KT120s, and deeper into the recording.
The EL34s are not bad at all, and I could live with them if I had to, but the KT120's just edge them out by half of a stride when biased up higher at 80 mA or so. That's my analysis anyway.
Compared to the Winged C EL34's, are the KT120's good enough to drop everything and go out and purchase a quad? No, not if you already have a good pair. But if you're looking for a slight upgrade and have the juice to run them hotter, I think the KT120's outshine the Winged C EL34s, but just barely.
Your mileage will probably vary, or in other words, all in my opinion.
