Empire 2000 E/III Questions
hamraisin
variable optimist
Recently picked one up and it sounds really, really good to my ears.
Two problems - like my friend who has exactly the same cart, upon dropping the needle there is about 1-2 seconds of popping, like static. I would have thought it was my system had I not heard exactly the same thing at his house - any ideas?
Other problem - this cart rides real low (sorry don't know the terminology), and on slighty warped edges, grinds along the record. You can imagine how good that sounds - what can I do about that? Running it at 1.5 grams - would lighter be better?
The suspension may have collapsed.
You can replace the stylus. :music:
everyones running this cart now it seems. i get some static for a few seconds too slightly more than my other turntables carts, im just starting off with a new stylus since its cheaper than a new cart.
i had to up mine to the top end of the cart at 1.5 to get consistent tracking
that is the cage/frame of the cart?
yeah, I gotta get myself a quality magnifying glass - the last thing I need for my toolkit.
This is the original needle.
The part that is supporting the cantilever and keep it at the proper angle, it in part the stylus carrier.
May be time to replace the original stylus. :idea:
Does that comment "everyone's running this cartridge now it seems" mean it's become trendy?
There's been a 2000E/1 body only sitting in my cartridge box since 1980. A customer came into the shop (Empire dealer) I was working at wanting a new needle. We were out of stock, I sold him a new, probably Shure, cartridge and he abandoned the Empire. I did not like the look of Empires but took it home anyway and so it sat for 37 years. For the last 10 or so, the thought of getting a new stylus crossed my mind, just to try it out, and I acted on it about 2 months ago. I wound up getting one marketed as being for a 2000E/III (clear plastic grip), made in Japan and came in Tonar packaging.
I've been using it exclusively and like it, especially the bass range. I played bass guitar and seem to notice that first. I do not know what dimensions the actual stylus is, the package did not say neither does Tonar's fitment chart and the vendor was uncertain. I suspect it is .0003 X .0007, not .0002 as was the original but it is fine regardless - tracking @ 1.5.
I've been outfitting a number of orphan cartridge bodies lately just because but cannot entertain the notion of anything other than affordable stylii. For the $25 or $30 this one cost, it was good value.
yeah, I gotta get myself a quality magnifying glass - the last thing I need for my toolkit. This is the original needle.
I believe there's a thread somewhere on fixing collapsed suspension with a little WD40
Thanks - I just picked this up - fingers crossed! Will check out suspension also when replacing
thanks gents
Have you tried tracking lighter, so body doesn't touch the LP? My E/III tracks fine at 1g, even at .75g, and rides higher. But it's NOS — obviously that's a difference, but the suspension is the same age, and age, not use, is the usual cause for degradation of the suspension (because chemicals in the elastomer evaporate, air pollutants degrade it, etc.) You may have tried lighter VTF already, but didn't mention it... It's a superb cart, well worth getting right...
I brought it down to 1g and it was still pretty low - I am going to tackle it in total when the new stylus shows up
I recently bought a Dual 1009 and it had a very old ADC that has seen its better days and so today I changed to the Empire 2000 X/III and it's a very noticeable improvement.
Very nice depth and imaging.
It took some time to get it balanced and I do hear a bit more noise on older records but the sound offsets this.
Hi all, I've had an Empire 2000 E/III cartridge since I was 18 years old (I'm currently 63 years old, so a few years have passed...). I took my turntable out of the attic, I restarted it with this cartridge, and when I looked for the original box, I realized that I must have inadvertently thrown it away when I was tidying up. Does anyone still have the instructions that were in the box? Thank you in advance;)
What information were you seeking in the literature? Many people here seem to know these things.
Your English seems proper.
Thank you for this answer, it's great :)
It's nice for my English, but I also get help with a translator ;)
I'm actually looking for documents reproduced from originals, which were in the box of the 2000 E/III, in particular the characteristics or the response curve for example.
If I remember correctly, there was indeed this kind of information on the instructions in the box.
Otherwise, I was recently able to get a 237 det dec stylus from Switzerland to replace the original one, but I was disappointed by the result, even after a break-in of a few hours. Then I got a Tonar 667-DE from Japan which really sounds much better, very close to the original. What do you think?
It seems that the Jico are the best in this field, but since they are naked, I am always afraid of damaging the diamond, especially since small children are often around... I've always had the habit of lowering the stylus protection after each listening, which exists on the 667-DE as on the original one.
And I wondered if the price difference was really worth it, especially since once I'm over sixty, the ear is not the same as when I was young :rolleyes:
I forgot to present the material I'm listening with:
Sherwood PD-701 - Very simple but reliable and very quiet turntable compared to many others I have tested
Pioneer SA 506 2x25W Total harmonic distortion < 0.07%
2 x 3A Auditorat Phase Plus 60W 92dB/1W/1m
