Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
My Empire 598 is very sensative to the slightest warp in a record. Brand new records will skip on the first track if there's any warp at all. These records play fine on my Empire 208. Any advice will be greatly appreciated. It may be the rubber platter cover?
It must be that the whole arm is easier to move than just the stylus. That's why it jumps .off the record. Normally, if the stylus is compliant enough, it will move up and down with the warp and the arm will stay in place, or relatively so.
That is an anti-skate problem. Try rotating the tonearm platform (the piece that the cue level is attached to), counterclockwise about 5-10°. That should eliminate the dead spot in the lead in area/first track.
Anti-skate seemed to alliviate the skipping somewhat but not entirely. I just got a brand new pressing of a record. Side 1 plays fine Side 2 does not. I can see the warp go by as the platter turns and it causes the needle to skip. Tomorrow I'll bring that record to work where I have another TT. I feel pretty sure it will play fine on that one. Meanwhile I'll keep trying things.
Also, is the original Empire mat being used? That mat supports the record by the outer rim and does a very effective job at taking out warps............
I brought home an album from my office that skipped on the first song(on my Empire 598) and I'm happy to report it played almost perfectly after I adjusted the anti-skate mechanism. I didn't have a chance to try the other warped album on my work TT but I will next week so progress was made. Thanks Wayne and all who responded.
The Denon DL-103 of any model is a major mismatch on this arm. It's on the low mass side of things for the era, it was used with the Empire cartridges like the 4000 series, which were high compliance. This arm was made when Shure V15 Type III, Stanton 681 EEE-S, Empire 4000. and other similar MM and MI cartridges were dominant. When tracking forces were often 1 gram or barely above, and high compliance designs were most common and popular.
