The Mighty Empire Praise and Curse
Hello lads,
thought I would chime in here. I discovered the Empires two years ago, with the purchase of a 598 III. I like them so much I now have six. Two each of the 598 III, the 698 and the 398. I have yet to own a better table under $1500 than these. If set up up properly, and taking the time to really figure them out. You might find like I did as to what a truly great turntable they are I sold off a pair of Dual CS 5000's and a Music Hall 5.1 as they sounded like your mom's old 45 player next to them.
I have discovered a lot of tips and tricks for these, including the fix for the infamous 598 cueing problem.
But as for the cable, remember, it is 35 years old, Mine all still work fine, but there is a few things you should do and one that is a work around.
First replace your RCA connectors with a good quality ones with a strain relief.
the second, it's probably not your cable at fault. it is more than likely the Female plug in the arm. The female connectors are of course split spring tension metal receptors, and they were originally installed in the plug as a press in fit with just a dab of sticky. now, after 35 years they have lost the springy, and/or they are getting loose in the plug.
The cheap and dirty way around this is to drill a hole in the back of the plinth about three inches to right of the tonearm plug and in the center of the plinth. Feed the cable through the hole, and the tension of the cable having to make a right angle to reach the tonearm plug helps keep it in place.
The correct way is to rewire the arm and install new/better female connectors in the plug. Not easy on an empire but worth it, or you can rewire the arm, drill a hole in that plug run wires out to RCA females, plus you can bypass the two connection setup on the clip by using cardas tags on the end of the wires and do a straight connect to the cartridge. Then you have one connection from cartridge to RCA instead of the four that you now have.
Just about any tonearm that is this old could stand being rewired. Most people don't even blink at rewiring an SME arm, So why not this one?
Getting the 598 and 695 platter level is very important, take a standard cheap wood ruler that you get free from the hardware store, and cut it into three equal length pieces These rulers are around 3/16th's in thick and this is the clearance the manual calls for on platter to base clearance. place one of the rulers at each of the three adjustment points and slip between platter and base. adjust the screws until up and down until all three rulers are a slip fit between the platter rim and the base. You should then have a level platter and the suspension set correctly.
The Arm height and the swing of the arm across the record is tricky and I will need more time and photos to do this as well as the cue problem..
But I love these tables and I have for cartridges in them a Shure V15 II, an Empire 4000II and an AT 440 all three give excellent results, and I think you can use a wider range of cartridges than is thought. as for the 980 and 990 arms,I really don't know if you can call them a high low or middle mass arm, as to the cartridge to use, as I am having good luck even with an Ortofon OM10 cartridge with no appreciable record wear, and decent tracking.
You can swap out arms on both the 398 easily and the 598 with a little more work and the right arm. But the main thing is that great platter, and that famous never die motor.
Till later.
Donald Bowman
