Empire op2
Digiverse
Hi Guys, Any thoughts on a Empire op 2 cartridge with stylus new in box ? will it suit my TechniCs SL1400 ? and Sansui AU 101 ? All opinions considered and thanks. Groovetube.
Work just fine and should be cheap as it is not a top performer. 2.5 gram tracking force
Instead of bombarding the board with every cartridge you find, do a bit of pre-posting research on the vinylengine.com. Their cartridge database, the turntable database (but you might not find what you need, the effective mass of the arm, so use 18 grams say) and the cartridge resonance calculator.
Or put all the nails (shape things we stick into records to listen to the music) in one post and ask which is a good fit to your TT. No price discussion in this forum but if you need that info, use the dollars and sense forum. Sure your post count won't skyrocket if you put all these questions into one post but it might help.
I did
Hi Blue Shadow, Thanks for all of your replies I did originally pool them all together twice this week with no response so I thought oh well I will just separate them then and guess what ? I am now getting the responses. Cheers. Groovetube.
