Krosya
Well-Known Member
Hi All,
Scored a pair. In fairly good shape, all drivers work, but of course surrounds are gone. I tried to find replacements on an auction site - results seem to be conflicting. Some call for 6 inch foams and others for 6 1/2inch. Looking at the specs - they have 6inch woofers. However measuring them - 6 1/2inch - inside the basket frame where outer edge of the foam would be. Cone itself seems to be 4 3/4inch.
So what size foams do I need? Anyone has done refoam on these? There is not that much info in this model. Also, it looks like original foam was glued Under the cone (to the side facing back/spider), which is first time I would be refoaming speakers that have this - all I have done were on the top - so question - is it more difficult to glue foam on the underside? Any tips/tricks for this?
Also, these have stuffing inside the cabinets (like most acoustic suspension speakers do), but it looks like its all lined in thick layers along the walls, but not much in the center of the speaker box. Should I add some more, make it more packed for better low end? ( well, I dont know if they need a better low end yet, but was wondering if anyone who has these have done this)
Any help is appreciated.
These are the speakers: http://www.humanspeakers.com/e/epicure-5x.htm
