ew, feedback loop tone controls. Mind linking to the schematic you're using? I'm finding several different ones here.
still, off-value parts in the tone control circuits will screw things up. Pots tend to be bad about drifting and that skews the response of the controls considerably.
Output transformers as a rule haven't gotten better, but thats not to say all old ones are perfect either. I will tell you that if you do a transformer swap in a feedback amp its pretty much guaranteed to perform differently. Whether its good or bad depends on the specifics but its going to need the feedback and stability evaluated and very likely re-tuned. The supersonic characteristics of every transformer is different and its easy to have something go off the rails with improper tuning. Tone controls in the loop make this all vastly more annoying. A power amp designed for flat response is a lot easier, stick a bunch of caps and resistors in there which screw up the phase response and its very much a gamble.
