I'm not sure what "punch" is either, but adjusting the gain of the phonostage shouldn't do anything at all to the sound quality except make it louder (or quieter).Granted, the gain adjustment provided more punch, but the overall sound reproduction remains dull, flat, and without depth.
By punch, I meant increase in volume.I'm not sure what "punch" is either, but adjusting the gain of the phonostage shouldn't do anything at all to the sound quality except make it louder (or quieter).
Well, I replaced the Pyle with the ART DJ preamp and played a few tracks from the Dan's Pretzel Logic. I wish I could say the new preamp made a much better and significant difference in reproduction, but I cannot. Granted, the gain adjustment provided more punch, but the overall sound reproduction remains dull, flat, and without depth.
I will replace the Orotfon Red cartridge with the replacement I received the other day, but I'm not expecting any improvement in sound. I will just put my records back into the closet until I can afford new speakers.
I really appreciate everyone's assistance here.
I am in Tampa.Where are you located, someone here might be near to you, and able to help you with getting it sorted. If I were near you, I'd be happy to do so myself.
The turntable is connected to the receiver's CD input because the receiver does not have a dedicated phono input. I will check for another available input and try that.While it could be 2 defective units, the odds are the phono preamp is now known to not be the problem. It is isolated to the records, the cartridge, the phono cables/connections, or the receiver. There literally isn't anything else it could be.
There are still some really cheap things you can do.
1. Turn up the volume up so the phono is as loud as the CD. (They are different sensitivities.) Then compare the sound.
2. Try the TT in the CD input on the receiver (a couple of us have suggested this)
3. Bring it to someone else's house/shop and switch in components. That TT has a standard headshell so use the friend/shop-owner's headshell/cardtridge as a test swap.
If you really have the urge to buy something, get a the cheapest good A-T cartridge on a headshell e.g. https://www.amazon.com/Audio-Technica-AT-VM95E-Turntable-Headshell-Cartridge/dp/B07JLX1JZ7 If it sounds the same, return it. If it fixes the problem, get your money back on the now-known-defective Ortofon.
Second choice: Get a brand new highly acclaimed pressing of a record you want.
While the speakers may not be the favorites of the many anti-Bosers above, they are not defective if they work fine with the CD.
Don't apologize, I really appreciate all of the suggestions and assistance!So sorry about the headshell issue which was baed on my bad assumption, and for all the trouble you went through otherwise. Good luck, and thanks for a post that got a lot of people interested.
The Ortofon is most likely not defective.
