That logo on the bottom right does match. I wonder what they went to? Possibly with the Transars?Pretty sure. ESS was located in Sacramento, this box was made there, too.
ESS made 4 models back in the early 70's: Transtatic Monitor, Transtatic 1, Translinear, and the ESS 7.
The Transtatic Monitor was a bi-amp system. It used 2 KEF B139 for the low and 9 5"X5" RTR electrostatic panels for the highs. The placement of the 9 electrostatic panels were at the very top of the speaker. The sounds from top of the panels were design to reflect off the ceiling and the sounds from the bottom of the panels were reflected off a cone in the form of a pyramid under the panels. These sounds were to be disbursed all 360 degree around. Crossover was recommended at 800hz. It was listed for about $2000 per pair.
Cool! You sure you don't want to bi-amp those?![]()
2 of their current models cross over at 800Hz, the AMT Limited Edition and the LD-10LR.
The Limited Edition looks a lot like one of their old models to me.
Click on "More Information Click Here"
http://www.essspeakersusa.com/Products.html
FWIW - I'm currently building a pair of speakers with an Altec 416 woofer and a Great Heil with the Heil crossed at 1,000 Hz 3rd order.
Pic is of the temporary cabinets (Man I wish I knew how to woodwork, I'd have these in proper cabinets by now)
You’ve just said a mouth full of stuff that could make a guy feel a little defensive. There are reasons beyond being an eccentric, wealthy collector that can stimulate interest in these crossover units. As far as the ADS C2000 and how it could be used with my 1230s I have yet to understand how the 3 way crossover is designed. Some say the circuits are not fully disengaged when the switch in the back of the speaker is set for bi-amping. I am still interested in a C2000 and regret not purchasing one when I had the $400 and opportunity. Both the ADS and ESS fit with my vintage gear and I like the esthetic. I believe in function over form for the most part but I want both. The Heil Elite sitting on the Altec 891a with both in mint condition is a beautiful sight and I believe may give your AMT-3’s a run. I can get the ESS crossover for $150 which works for me. For amplifiers I can use my Eico hf-87 and my Dynaco ST-70 for power. Now I am sounding like an eccentric collector. Well it is what it is. I hope to be wealthy also but I am still working on that. As far as the great Heil performance, I am aware of its ability to reach down to midrange tones. This is not about the crossover part as much as getting the balance between a very efficient 4ohm speaker and a relatively inefficient 8 ohm speaker.
It occurs to me that we all must be audio collectors of sorts and a little bit eccentric to be members of this fantastic forum. Congrats to those of us who are wealthy. If I where I would probably have sheet rock on my walls and acoustic panels rather than just the fiberglass insulation covered by tarp. I might also run a Pathos instead of my Eico but I doubt it would sound much different. I can really dream! I would live in the Seattle Space Needle and have a tram that ran down to my yacht moored out on Eliot Bay. And Porkloin you would be invited over for barbecue. Since that will not be likely, you are still invited for barbecue at my current home.
Maybe I’m a bit touchy today. PMS? OK…..I’m Done!
