Ever seen OVAL voice coils?
never seen a oval VC.
strangest voice coil I have ever seen was in an old tube radio, it was like a solenoid that drive the cone via a small shaft. a voice coil only not??
Magnetic speaker, common type that came between horn speakers and electrodynamic cone speakers in the later 1920s ca 1926-1928. Philco used them in at least one table radio in the early 1930s as it could combine the speaker with no output transformer needed. They had wonky freq response as a rule.
Sent from my SM-N900V using Tapatalk
No, these are the ones I am familiar with:
Infinity has/had a midrange they call the MRS with a flat rectangular diaphragm and dual long oval racetrack-shaped voice coils.
http://harman-kardon.cz/infinity/data/maximum-radiating-surface.pdf
I have a single Sawafuji Dynapleat driver somewhere, look it up. Also have an RCA 100A magnetic speaker, and Utah magnetic speaker with the Chinese hat reverse cone, but missing the cone. Used to collect odd microphones and speakers but let most of it go years ago tho still have a few items.
Salvaged TV speakers??
Or some other size constrained fitment. Otherwise a Pointless design IMO.
I've seen Oval (more rectangular actually) pistons In Honda Factory Racing Motorcyles decades ago. Designed to allow 6 ! Valves to fit.
Worked exceedingly well but allegedly a bugger to manufacture.
I was in a shop watching the heads being removed from the V8 engine of a '61 Vette in the 70's and to my surprise the cylinders/pistons were triangular. Rounded corners but three flat sides. Huh?
"Magnetic speaker, common type that came between horn speakers and electrodynamic cone speakers in the later 1920s ca 1926-1928. Philco used them in at least one table radio in the early 1930s as it could combine the speaker with no output transformer needed. They had wonky freq response as a rule."
I have a GE pocket transistor radio from the 60s that used the same type of speaker.
I have seen some strange speakers inside of TVs:
-Inside-out speakers (magnet and coil inside the cone)
-Siamese speakers (one oval frame, one surround, encompassing two side-by-side cones and two voice coils)
Piston crown shapes I presume.. Lotsa those about... in early-ish engines...Google?
Honda had Rectangular Bores (with rounded edges :-)
Seriously tricky to Manufacture.. Imagine making 'effective' rings to operate in Flat out Race conditions
No no. Both 'cylinders' and pistons were triangular. Weird. I'm a car guy(or was) so not mistaken here.
