nottingham365
Guys/Ladies:
I have a couple of mid-fi setups with the same problem. I barely turn the volume control (a few millimeters) on the preamp and it gets pretty loud, making the volume control essentially useless. I would like to be able to make minor volume adjustments through most of the volume dial settings. Current sources are CD players exclusively. I have read that I could have a tech install one of the following: 1) resistor (voltage) dividing network before the pots in the preamp OR 2) attenuation circuit at the volume control in the preamp. I want the reduction to be effective for all line inputs. Would these options be effective? Would either be less sonically detrimental?
Any info is appreciated.
Ross
Systems:
harman/kardon hk 870 amp with harman/kardon hk 825 preamp
Adcom GFA-555 II amp with Adcom GFP-565 preamp
various CD players (Denon, NAD)
Monitor Audio GR20 speakers (pretty efficient) for both setups
Ross
Systems:
