Ive got a few different kinds of aftermarket mats and was pondering the finer points.
What kinds of mats do you use, and why?
I got a box full of assorted's awhile back and in there were a couple different kinds of felt mats. One says its an "Anti-Static/ Slip" mat. and is hard felt vs. other softer felt ones. Who has problems with their vinyl slipping? Under what circumstances might that happen? Seems ridiculous. So you've got so much torque turning the platter and your stylus digs to the deepest depths of the groove so well, that the groove to tip friction nessesitates the use of a traction device? WoW
A 1/4" soft rubber "music mat" vs. many different kinds of stock style mats of similiar thickness' of different durometers.
Combinations? a rubber with a felt on top?
Are changes in mats on more modern tables with solid, heavy aluminum platters less noticable than on a steel or thin alum. platter models......
Better on idler wheel vs. belt vs. DD.
Seems it could be subjective, based on the charecteristics of the table. And of course there is a VTA change in some instances Im sure. :scratch2:
