Before you slather this all over the place CAREFULLY check the silk screening to be sure you don't destroy the printing on your face plate....
remove all the knobs grab an old toothbrush, qtips, and WINDEX...carefully test in a discrete area...spray the Windex on the qtip or tooth brush NOT the face plate...the knobs I blast at will!!
I have cleaned most everything...years of smoke...grease...PAINT...and YES even some LETTERS (off of an old nikko) but like the shampoo says lather, rinse, repeat...I have found that with some patience the Windex does a real nice job on alum knobs, face plates, and the vinyl case...just BE CAREFUL as I said I did remove some letters but it has only happened once...use the toothbrush ONLY to get into those fine grooves, tough stains, and tight spots...use the qtips for most of it...
I finish the NON silk screened areas, knobs, and other "safe" areas with Mothers Mag and wheel polish...cleans up nice and leaves a protective coat...
Again this is what has worked for me...and I an thrilled with the outcome...but your mileage may vary...
