Hi all, I’m needing some help. I have a 5000a, and a f-1040 driver board repair/upgrade kit that I’ve been working thru. Before I started, it worked fine, but wanted to fix driver boards to ensure it stayed that way. Started with left, changed all caps, tested and all good. Then I replaced the transistor at TR801. Made sure the transistor was ECB correct according to the board which is lettering facing the opposite direction from original transistor. After this replacement I noticed audio much quieter, but still good on dim bulb. Thought is prob normal until bias is set. Proceeded with TR803/804, all good on dim bulb, still low volume. Proceeded to bias set. Bias showed .001 on meter and didn’t change no matter how I turned VR802. I’m guessing this and the low volume is related. I’ve double and triple checked, but don’t have enough experience to know exactly what’s wrong. I suspect something with TR801, but it does test ok. Any ideas?? Pics of board front and back.
