buck1108
Thanks. I have now replaced the faulty Zener diode, and the reading on the DMM is satisfactory at the Zener; however, the amp is still producing the distorted output. I will include photos of the scope readings (below).
I am focusing primarily upon the power amp push/pull section of the circuit, and I am going in descending order of the test points, starting at test point 19.
Here are tp19 and tp18. As far as the test points go, these are the only test points that show any mis-shapen waves.
TP19 (below) has a flat topped peak. This is at the Line Output, after the output at TP18 has gone through the 4.7Kohm, 1Watt resistor, R121..
TP18 (below) has what seems to be a disjointed peak. This is the signal, just before L1. Out of curiosity, what kind of component is L1? It looks like a large disc capacitor.
Would this wave distortion of the peak indicate the push section is faulty? Thanks.
