Voltages are OK. (I wanted to discard some "offset" of the signal, causing that assymetrycal clipping)
When I measure the input (U4, pin 6), the scope just shows a flat line at zero. I've had the scope on "AC" mode, but still no voltage reading.So, just confirm if the signal is OK at the input (U4, pin 6), and if so, I'd say: Signal is OK, voltages are OK, the 1st suspect is a bad OP amp...
When "Delta Comp" is disabled, there is continuity from U4, pin 7 to diode CR1/resistor R29, but that checks ok with the schematic. The schematic shows what must be "normal disabled" signal path. I also checked the "Delta Comp" for continuity between CR40 and R129 and there is none when "Delta Comp" is disabled.Make sure the "Delta Comp" is disabled, check you don't have continuity from U4 PIN7 to diode CR1 or resistor R29 before testing the signal at pin6.
I suspect there is something wrong at that point (not 100% sure tough, it could be the normal operation, but I don't think so). You traced the signal, and up to U3 output it was OK. So at U2 pin7 the sine wave is OK. That U2 pin 7 output pass through C17, R26, and goes to U4 pin6. I'd check again at both sides of that capacitor to confirm the signal is OK.
you are rignt, those transistors let the signal pass, positive and negative halves (follow the transistor's arrow). So probably one of them is saturating, or it's biased too high... But the fact that disabling that network restores the proper signal, tells that something is not OK there.
Did you swap them finally? (since now you have a flat bottom, not a flat top...)
I'd check those resistors and replace both transistors with new parts. I think it's easier to replace them than test them is some test circuit and so.... If you have some spare transistors you could use them, just check the voltage and pinout.
so at TP 15 YOU HAVE A CLEAN WAVE with "delta comp. off", THAT'S ok !!! I'd check the output under this condition.
That feedback network we were checking seems to be asymmetrical, the resistors are all different, I really can't tell what's the normal operation. Check resistors just in case, and the diodes, or reflow the solder, but if the output is OK, I'll leave this alone by now
Update: I replaced both Q1 and Q2 transistors, but the wave is still the same.
When monitored at TP6 (pin 7 of U4), the wave has a flat bottom when the Delta Comp is off.
When monitored at TP6 (pin 7 of U4), the wave has a round top and bottom (clean wave) when the Delta Comp is on.
When monitored at TP15 (pin 1 of U4), the wave has a flat top when the Delta Comp is on.
When monitored at TP15 (pin 1 of U4), the wave has a round top and bottom (clean wave) when the Delta Comp is off.
When monitoring the leads of Q1 and Q2, the wave shape is very un-sine like. In fact, there is some difference in the appearance of the wave from Q1 and Q2.
Do you think the next step is to replace the resistors?
