Was the documentation/manual written in English? I noticed the arm/cart gauge was in Chinese I think.
For selfish reasons I'd like to see better pics of the tonearm. Particularly a,close,up of the hole pattern on the air tube- if visible.
Peter,
What of about most all of our's favorite pre-play cleaning ritual, the carbon fiber brushing? Does the motor have the torque? Is there any perceptible upset of the platter? Is there a landing or centering bearing that keeps the Delrin off of the machined aluminum 'hub'?
Good stuff. It sounds like you have a winner on your hands.Today I brought in my rpm gauge and set the speed more accurately. Holding absolutely steady at 34 rpm ( my preferred speed). Spin down time from that speed with belt off is just under 3 minutes![]()
Weak point so far is the motor...I think it could be more robust, however it does it's job. And there is a slight ground hum that I haven't figured out yet. And it includes the ever annoying touch the arm hum. It could be my set up with all of those freak-en wires all over the the place!
Couldn't tell from the pictures, but is there a ground wire?
Maybe it needs a better PS of some sort?I was way off yesterday with my spin down time. From 33.4 rpm using my stop watch came to a dead halt after 12 minutes and 30 seconds.
The reason I timed it again is due to the speed variation I am getting from this motor. It has a 9 volt wall wart and I think it may be attributed to the line voltage at my workshop. It tends to occur more during the middle of the day. Late afternoon it levels out.
Any theories?
