It is very difficult for others to know what you would like best.
I can rank your alternatives according to my own tastes, but that would probably be of little use to you. Still, here you go:
You will get many variations on the ranking, based on the preferences of other members. Like me, they are neither wrong nor right as regards which ones would be best for you.
- Dynaco A25
- Boston A150
- JBL L100
- Technics (way behind the three above)
What is your budget? I would guess that the speakers you listed have a wide range of prices. And what are you planning to use for amplification? How big is your listening space?
Be aware that when buying used speakers you will need to inspect them (by both eye and ear) to be sure all drivers are original and working, and that the speakers are making no unusual noises (rattling, buzzing, static, excess sibilance, etc). Also be aware that with older speakers that used foam surrounds, the surrounds may need to be replaced. And if they have electrolytic capacitors in their crossover networks (as most older speakers do), they have likely drifted from spec as a function of age. Replacement often improves sound quality quite noticeably.
So many variables not the least is personal preference. If it were me I'd choose the A150 first then the A-25s though depending on music and room might reverse the order. Wouldn't consider the Technics and never liked the L100s from when they were new although for rocking out, beer in hand, they could be first choice. Either of them would have to be in proper working order, or course.Looking to get my first home setup to connect to my Technic SL 1200, found a pair of JBL L100's, Technics SB2680 from the 80's, Boston Acoustics A150 in mint condition, and a pair of Dynaco A-25s also in very good condition. Which ones should I get!!!!!!? Help plzzzzzzz
Ahhh... Yeah. If the desire is to turn it up, that's the choice.If you like to rock out, get the JBL's!
...Which ones should I get!!!!!!? Help plzzzzzzz
Do you already have an amplifier? If so, that would play into what speakers to choose.
Which speakers have you heard? What sound do you like?Looking to get my first home setup to connect to my Technic SL 1200, found a pair of JBL L100's, Technics SB2680 from the 80's, Boston Acoustics A150 in mint condition, and a pair of Dynaco A-25s also in very good condition. Which ones should I get!!!!!!? Help plzzzzzzz
I’m looking for a well balanced sound, something versatile in the sense of a wide range of genres! This far have only heard the 901’s. Boston Acoustics tomorrow, Advents and Dynacos on Saturday.Which speakers have you heard? What sound do you like?
Thanks!
