tomlinmgt
Lunatic Member
I can see how that would change the amplitude, but to assuage my own curiosity, the actual reflection point would remain the same, correct? Do you forgo the mirror technique with different dispersion types and have to figure out a different 1st reflection point location in a different way?
I should have stipulated it's more the ceiling and floor primary reflections that become a non-issue with line source dipoles. They have a null zone as you move off axis in the vertical plane above and below the driver. Because of this, primary reflections are not as critical on the horizontal boundary layers (since very little content gets dispersed to the primary reflection points there). Many in the line source dipole camp claim sidewall interaction is less of an issue, as well. I think there is some validity to this statement, but don't believe it to be absolute. With a dipole as you move from on axis to 90 degrees off axis the strength of the sound wave weakens until ultimately you reach a null zone at the sides of the speaker. Since the content dispersed to the side walls is weaker than what is typical of a monopole there will be less interaction with the side walls......but still some and, though the sound wave that reaches side wall primary reflection will be weaker, it's still content that will reflect back into the room. Personally, I still want (and have) absorption at side wall and ceiling first reflection points with my line source dipoles....but it is widely agreed upon that dipoles do not suffer the same room interaction issues that monopoles experience. Linkwitz has gobs of info regarding this....it's the fundamental concept from which he bases his designs.
So, replying to your question with a more direct answer I'd say no, different designs don't change the primary reflection locations but some designs, as I've pointed out, aren't as influenced by them as much as others. Which, after reading over Wavetouch's post/infomercial again, see that he touched on that in his sales pitch.
