pauvro
In Training
Hello,
Awhile ago I got a good deal for a pair of Cerwin-Vega VS-100's. These were the best speakers I had ever owned and I enjoyed using them. It didn't take long before the original foam started to crack and come apart, causing the sound to get worse and worse until I just couldn't use them anymore.
Anyway I decided to get a refoaming kit. I watched a video addressing how to complete the refoam, read up on some information, then jumped on in. I'm not quite sure what went wrong but now I have one speaker that sounds good (can't hear any sort of rumbling or distortion anyway) and one that rumbles and rattles on low frequencies, it's quite annoying.
Initially when I recognized this sound I kept trying to locate it. Thinking it was the dust cap, I removed it and attached a different one, and put the speaker back in the cabinet. It seemed to work initially without any distortion, but the issue soon came back.
When I refoamed these, it was admittedly a little stressful. Scraping the original foam off was quite tedious, I did manage to get a decent amount removed to make it feel flat then I remember when gluing the inner edge of the surround the surround itself didn't seem centered on the frame but I heard that's to be expected. When I went to glue the outter edge I couldn't get some of it to actually adhere due to the fact that it wasn't fully fitting the frame. I did everything the way it was said to be done however I did rush it a little when I did the second one...when it came time to "center" the voice coil all I did was use the shims that came with the kit and places them at a 12, 4, and 8 o'clock position. That's the extent of what I did with centering it and I'm not quite sure I would know if that were the problem or not...like perhaps somehow it became uncentered...even though I used shims?
My question is given this information, what should I do to fix this problem? What information, if any, do you need from me to help figure out how to fix this problem.
Thank you for any help.
