jaymanaa
RIP 1961-2018
I have to admit that I've always been in the group that says if a wire will carry the load, has decent capacitance, and good connections it will work as good as any. Well, tonight I'm putting together a new system and figured I'd try a higher end interconnect and speaker wire. The first pic shows my usual on the right, and the fancy interconnect on the left. The next two show that they do fit properly and have good connections (the fancy cables are even pretty).:yes: The 4th pic shows the new speaker wire (I usually use 16g. brown lamp cord). This new stuff is from the car audio section at WalMart. It is oxygen free 14 g. copper. They only had it in blue.
The fifth pic shows the components I will be using to conduct the tests. Harmon Kardon CDP to Entach 205 DAC, to homebrew pre running GE Triple Mica JAN 5814s (fancy 12AU7). From that through the cables to be tested, to a recently restored and electrically upgraded Harmon Kardon 250. It's running RCA cleartop 6CG7s, and TungSol brown base 5881s (with Hexfreds doing the rectification). The speakers are "slightly" modified W60s (thankee Ron).The material will be rock (John Melancamp's Cutting Heads CD), Jazz (something blue note, probably Burrel and Coltrane), and antigue blues recordings (from the Time Life series Copulation Blues). Anyone want to make a prediction, or suggest a change in anything for testing purposes?
