Well of course you had to burn those babies in....nuther couple hunnert hours and she should sound great....![]()
If I could add my thoughts I would suggest your sort of comparing 2 turds to see what one is less offensive. OK that was a joke but seriously you talking a $13 gap in price between the two, is it safe to consider this test might be of little value if your going to try to claim this as a definitive cable test?
I hope you hear a difference because it often is there but incase you dont I think trying some cables from a company who actually cares about what it is making may be of more value then a set potentially assembled by a child in China. I like the fact your curious and open minded enough to try this out.
Have the Mrs. swap them randomly to see if you can tell any difference.
Quick question for the EE types here. I soldered the ends of the speaker wires so they wouldn't fray. Will the solder cause any loss of conductivity over just clean copper.:scratch2:
Of course those cheap cables will sound good on that old tube stuff you use. We all know it can't produce highs and lows like the modern equipment can.
I'm a little disappointed in you Jay.
Owich! Welcome to Friday Night Smackdown on AK!![]()
Might be better to dip the ends in your solder pot filled with molten gold. Just melt a bit of the Mrs.' jewelry. When she hears the results, she won't be mad any more.
Do you know what's in those $$ Philips cables, wire wise????
I ask because I scrounged some RCA cables once that looked nice with gold ends and braided shields under clear plastic. But when I cut the buggers down to make some shorties, I found out the friggin' things were steel...
Make she is nude when she does so, thus minimizing any spurious noise or EM fields caused by asymmetric static charges caused by moving clothing. She will, I am certain, be compliant when she understands the physics involved.Have the Mrs. swap them randomly to see if you can tell any difference.
... The 3 buck cables weren't doing anything below probably 120Hz, and everything above that sounded like wet cats in a bag...
That's sort of what I was thinking. The 3 dollar ICs are as good or better than anything they had in the 50s. I switched out to the 15 dollars ICs and it literally made me laugh out loud. The system sounds totally different. It was hard to believe that I was listening to the same stuff. The 3 buck cables weren't doing anything below probably 120Hz, and everything above that sounded like wet cats in a bag. I'm really quite shocked, but in a good way.:yes: I'm fairly convinced though, that these 15 dollar jobs are probably as good as it will get (just with ICs). Now I will put in my 16g. lampcord wire for the speakers and see if I can here anything get worse.:thmbsp:
