heekma
Well-Known Member
Thanks again for the kind words guys, I sure appreciate it!
Hey, hey Craig!
Whaddaya know, I DID it! Firing that thing up and hearing music come out of it was about the proudest I've been of myself since college graduation day.
You don't need those specs of yours to see what you're seeing-there are a few mechanical connections. If you need a closer look though, you can click on the thumbnails for a closer view-but even then the images aren't huge.
I went back and forth on the barrier strip for the pwr supply-I don't like the idea of stranded wire anywhere, and the 10 or 12 gauge secondaries of the filaments were also big enough to be a pain to route cleanly and solder to the tube pins.
In the end, neatness, terminating and keeping the standed wire out of the circuit trumped soldered connections-but I appreciate the advice and will keep an eye on them. I'm using an old severly mis-matched quad of red-headed-stepchild 7591s that are mismatched enough to not quite balance perfectly even at the end of travel for one of the DC balance pots.
I'll be ordering some new 7591s next week so when I re-balance I'll be able to tweak those connections.
Thanks for taking a look Craig, means a lot to me.
Hey, hey Craig!
