…881,771,661 are DC amps, 331,221 are capacitor coupled design, different sound,more mellow,musical than DC amps which are more linear,dynamic...
Important point!
Not sure if you were asking me or AITinkster92. I haven’t got my speakers yet for this set up, I’m on the look out for them too.What speakers are you using? How sensitive are they? The reason I am asking is if you have speakers above 90 db, 331,221 might do the job. If you have something like AR speakers ( 86 db ) then I would do with something with at least 50 w/ch. 881,771,661 are DC amps, 331,221 are capacitor coupled design, different sound,more mellow,musical than DC amps which are more linear,dynamic...preferences aside all of these options will serve you more than fine,just might run into some problems if you decide to crank it up sometimes.
As already mentioned 5000 is great options if driver board is updated. If not I would play safer and go with 4000,2000,771,221...
If you ran into sansui 800 that would be the ticket!
Ops,my bad! Thought I replied to you... Anyway, as I said low wattage amp/high sensitivity speakers or more watts with lower sensitivity speakers. Sansui will mate good with most of the speakers, no worries.Also older Sansuis are good with 4 ohm loads, you don't have to worry. Since you already have NS 10, maybe try different flavour...something vintage...but that is up to you. Recently I hooked my 2000x to my friends Triangle speakers ( big floorstanding towers ) the sound was sublime...realy plenty of options here...Not sure if you were asking me or AITinkster92. I haven’t got my speakers yet for this set up, I’m on the look out for them too.
Or other set up is NAD3020 with NS-10’s for music production so quite a different application.
The Push Button Labeling falling off, and in many cases never to be found again
I bought new replacement labels for my Eight from @smurfer77 on the forum here, they are top quality!
