Transformer hum is a different issue from hum in the speakers. Transformer hum can be anything from loose mounting bolts to loose through bolts, to a loose coil form inside the transformer.
As for the hum from the speakers, the information regarding the Aux input is confusing. So:
With nothing connected to the Aux input, the Aux input selected, and the volume advanced, there should be little if any hum at all. Is there? Or is there not? Let's get this established first before moving on to the phono section.
Dave
Yes, sorry that was confusing. I was all worked up and should've slowed down. It's a little vexing because the symptoms seem to shift each time I power it on and listen for a while. I'll try again. There is very little humm with nothing connected to aux, aux input selected, and volume advanced. There is a very small amount, but not enough to concern me at all. This is consistent with what was happening earlier.
It's the level of the phono humm that was bothering me, along with the pitter-pattering sound. I noticed upon running through things again that this sputtering is now happening in both channels, and they both stop doing it when I touch tube V16. It was just the right channel before, and I had made a special note of that. The sound is very slight, and I can only hear it when volume knob is around 11-o-clock position. It increases as volume increases. This rapid sputtering happens with or without a turntable connected to the phono input.
The phono humm goes away with no turntable connected to the phono input. Does that suggest a grounding issue with the turntable and the receiver? I tried to eliminate a ground loop as an option by switching turntables, but it was present with either connected. However, now the humm is not as noticeable even with the originally-offending turntable connected. It is still there, just much lower level, and now not really enough to bother me. I did move some power cords around my entertainment system, so perhaps the humm was just being picked up by the RCA cords of my turntables? I thought I had eliminated a ground loop, but that may be all that is causing the humm now.
I suppose this is still a little confusing since the humm has been moving and changing, but perhaps some of my troubleshooting helped the humm. The sputtering sound that I hear with the phono input selected is still a little concerning to me. Thanks again.
