Thanks for your reply.500C is a gem. Built like a tank, very good OPT, top quality original german capacitors.
Attention must be paid to the volume pot which has a loudness tap. Quite expensive if you have to replace it. If sound is not even between the left and right speaker, the first culprit would be the volume pot. Make sure that the sound is even and the volume pot is ok.
The filter caps are the next thing you should care about. low voltage filter caps are usually way out of specs; high voltage ones should be ok. But this issue can be fixed quite easily.
Revision and checkups are needed for any vintage gear. Original transformers are also a must.
Hummm, I see only one there. Are there any more? By the way. I see several Teapo caps. Are they good?....Esthetically speaking, i will not use radial lead type capacitors for that kind of project...
12ax7 are Telefunken and MullardList of tubes (what brand, condition …) should be specified because these tubes count heavily in the final price. Upgrading tubes is very expensive, especially 12ax7 and the power tube quad.
7591 are Sylvania. All test strong, according to the seller.
So, this ' restoration' that the seller mentioned doesn't look like a quality job. I'll think twice about this one.There's 5 or 6 Radial Electrolytics. There are also some axial's that must be replaced.
Pioneer has it's shoot on site transistors, Fisher has "SHOOT ON SITE" capacitors. The 1st two are axial 4.7uf and lower. Rubber insulators on both ends bulging and sometimes just hanging on the leads. Brand name FRAKO & DUCATI.
Bunch of Epoxy covered Film capacitors (commonly called "DOG TURDS") The hard shell breaks down and flakes off, or the leads separate from the film stack internally, causing intermittents. These caps are either BLACK or Brown.
Thanks for your good advice.500c deserves better caps than Teapo.
In brief, 500c is a gem. I would grab it and pay a good price if volume pot and other pots are good, with all strong vintage tubes (not new production) and all transformers are original.
Thanks for confirming the ruling of other gurus ahead of you! I have decided not to buy this "restored " unit.It also looks like a number of caps were simply left in place and bypassed with a new cap, and other caps needing replacement weren't addressed at all.
Dave
