Weld Engr
Howdy still working on my 800-B and believe I have some capacitor issues (silver mica disease?) in the IF transformers based on reading posts and other searches. I have not verified voltages V5,V6 and V7 yet and do not have good tubes to swap in for testing at the moment. I do not get a heart beat 400kHz away on another AM radio. If someone has figured out the values on ZZ50210-1 and ZZ2984 I’d appreciate it. I found the procedure for using variable ceramic caps to determine it so I’ll go that route if I get there. Getting the AM alignment done isn’t something I have the tools or knowledge for so I’m going to have to find someone in MI most likely.
I only have static it will vary a little as you go thru the tuner range but just static. Going to work on voltage checks and pulling the ZZ2984 this weekend. Thank you
Wes
Wes
