It beyond the scope of this thread but there are methods to determine what you mention and the math to quantify it. It is how engineers design things and measure their operation.
What are you judging with a fixed point or a single pot and how are you judging it?
Understanding the operation of the particular circuit in question will go along ways to answering your questions.
It is true that there is debate and experimentation here regarding the preferred topologies of amplifier design. By understanding the operation of a circuit, the math can give us an insight to the instantaneous operation of the circuit in the time domain. Other math can tell us what is happening in the frequency domain.
One can characterize the operation of an amplifier in the time domain, frequency domain, with relationship to phase versus frequency, with relationship to group delays and so on. These characterizations among other things can tell us if we are getting in the ball park with our design or if an amplifier is close to operating correctly.
We know in a general way, based on the information supplied by the vacuum tube manufactures, electronic theory and experience, how a vacuum tube will behave in a certain circuit with certain applied voltages and certain amounts of current flowing through the vacuum tube. It is called the transfer function of the vacuum tube and the circuit in which it is used.
This is how we can arrive at the basic design.
Its not that important to me the bias issue as long as the amp runs and sounds OK , just trying to understand why changing it is so important to some people, no one has said for tone or linear reasons, that was what I would of expected from audio files.
To quote myself
The impact on sound quality of various parts and types of parts and adjustments in a circuit is much debated on AK. It is another can of worms.
Adjusting the bias in an amplifier is about setting the correct operating point for the vacuum tube
In general we set the operating point of a vacuum tube so that it will operate in the most
linear portion of its forward transfer function curve in the circuit. That is will help insure the the output signal is as close to the input signal as possible, in other words it is the most linear. You mentioned something about setting the current flow in a vacuum tube in your first post as being an incorrect thing to do What do you believe the correct thing to do? The goal is to set the operating point of the vacuum tube in the circuit that it is in so that it is operating in the
most linear part of its forward transfer function in the circuit. There may be reasons to move the operating point a little and that is another topic that is open to debate.
So your contention that no one mentioned it is not correct. The perception of sound quality is subjective and there may be no clear agreement on the definition of what sounds the best or even the changes in sound quality with various changes in adjustments, whether the adjustments are made to a fixed point or are variable.
Anyway, why did you claim that I had not mentioned it?
The design of an amplifier on its technical merits is one discussion. The merits of its sound quality are another although related discussion.
When a thread starts from a technical perspective it is safe to say that most will respond in a technical nature, especially in the Fisher forum.
Up until you edited at least one of your posts (I looked back, you have edited most of your posts), you had made no mention of tone (sound quality?).
Again, we can debate the relative merits of various designs in term of sound quality until the cows come home and that is okay, but it does not change the basic tenants of amplifier design, characterization and operation.
BTW, it does not help those that are trying to answer your questions when you go back and make major changes to your posts. Most of use are not going to go back and read a persons posts from the beginning to see if there have been major edits. Why are you changing your original posts so much?
Again, the debate about sound quality is subjective and an amplifier does not operate all by its self. There will be other electronics, speakers and room acoustics involved. The particular changes in sound quality as described by the listener will technically only be valid for that listener. This may result in some saying that a particular change makes the sound brighter or duller or whatever and another person may say the opposite.
This a a discussion that we can have, but it is not the discussion that you started.
Again you have edited one of your posts and added a question and a picture. If there are more post to this thread, it is likely that people are not going to go back and re-read your posts to see if they have been edited.
I could tell you what it appears to be, but and I am trying to be nice, I do not want to argue about it. A quick look at the circuit will tell if if it needs to polarized, non-polarized or that it does not matter. In term of tone quality as you call it (sound quality?) there are plenty of debates about capacitor types and the replacement and upgrading of capacitors.
