FireGuruMN
Oh no, another console! The woodwork on this one is in pretty rough shape. Missing the legs and lots of watermarks. But the previous owner used it as their daily music source! Apparently the "balance" had to be mostly to one side to get it to sound good.
The front view:
The Chassis (100T I believe):
The amplifier (SA-16)
The insides of the amplifier:
Where to start? First I want to get the outside work done before the winter sets in. Does anyone have dimensions or a pattern or a good picture of the legs? I found this but it is in a 3D sketch and not much good for determining dimensions. Are the legs slanted outward AND cut at an angle inside?
It will be hard to find a matching vase to sit on top also.
Notice that there are no rectifier tubes on the amplifier. There are diodes installed and the heater wires have been cut. Other pictures I see from the internet show a capacitor installed in there also. The wiring lug for the cap does not appear to have ever been soldered. So was this a factory modification. Not in 1961 if my electronics history tells me anything. There is also a socket behind the can capacitor that never appear to have been soldered. I probably want to switch this back to tube rectification and all. I found a picture of one for sale and it looks like they put a switch in the socket by the capacitor. So what was that ever used for?
I have everything cleaned up. I used some "LA's totally awesome cleaner" from the Dollar Store. It lives up to its name. I saw it recommended on a youtube video. This is the first time I tried it out. It dissolved all the gunk and left the lettering intact. I blew the loosened gunk out with an air compressor and let it dry. Almost painless.
I ordered new caps and tubes (except for rectifiers) for the amp. The existing ones were not good and I am surprised they were even making music at all. The original Fisher 12ax7's were good. Some of the lettering was missing from the amp before I started. I might end up painting the amp chassis since the lettering is in bad shape and the raw metal is not the prettiest. I have not gone through the preamp yet. I'm distracted by a ST70/FM3/SCA-35 that I reeled in. Original Dyanco power tubes and all!
oh, the speakers work but are dull because of the old capacitors. I have not tried the turntable. There is no spindle. . .
The front view:
. And they even act as a pretty good bass trap so the room sounds better.
