I have now completed my restoration on the KX-100. To summarize, I replaced all the signal path caps with IC Mylar units. The filter caps were replaced with Hayseed Hamfest replacements, the power supply diodes were replaced with modern units. The 2500 ohm power resistor R72 was replaced with a 2700 ohm unit to lower the screen and other voltages a bit with modern 120VAC line voltage. An inrush inhibitor was also installed in the AC line.
I replaced R71 with Dave’s Zener diode mod and replaced C4 with a 200MF 300V unit which I had on hand. I read (somewhere) that increasing the size of the cathode capacitor would reduce the cathode voltage variation a bit, providing a more stable bias voltage. Not sure if this is true but figured it wouldn’t hurt. The 10-ohm cathode resistors and the 100 Ohm screen stability resistors were also installed.
The bias network was also modified to allow each 7868 output tube to be biased individually. I set each 7868 to 42MA which provided 48V for the heaters of the 12AX7’s.
I then attached my IPAD to the aux input as before and listened to the amp for a while. It sounded quite good to me and I waited for the parts to arrive for the NFB upgrades. In the meantime, I did a side-by side comparison with a similarly restored KX-100 with original Fisher transformers. The amp with the original transformers sounded different for sure, with more “presence”, it was easier to discern the individual instruments and the vocals were clearer, at least to me.
When the NFB parts arrived, I installed them in one channel only initially to see how different the two channels would sound with and without the modification I used a 2.7k/500pf resistor combination as 500pf was the closest I could find to 450PF. Interestingly, 2.7K/500PF is what the fisher 400 uses in it’s NFB network with 7868’s.
The channel with the NFB mod installed definitely sounded better to my ears so I modified the other channel and listened to the amp for a while. It sounds quite good with the NFB modifications, amazing how two components in each channel can change the amp’s sonic characteristics.
Here are some pictures of the KX-100 after all the restoration and modifications were completed.
