Googled:
Record player MT-6410
A heavy pressure pouring aluminum plate plate also in-milled stroboscope marks coins/shapes the technical picture of this semiautomatic HiFi record player. With an electronically regulated, matured direct current motor and the belt drive this record player has a ausgesproche solid technology, which guarantees quiet running unc good synchronisation characteristics. Flutters amount to after WRMS also only
0.05%.
Magnetic pick-up the system with a sphericalally polished diamond is led in a straight ultralight clay/tone arm trägheitsarm across the disk surface. An viscose rayon-absorbed bore fixture serves as a clay/tone arm putting on assistance. Taking the clay/tone arm, the feedback off into the quiescent position and the complete Endabschaltung of the engine take place automatically at the end of the plate or on depressing the key for interrupting the rendition.
The change-over of 33 to 45 rpm takes place likewise over push buttons, the respective micro-adjustment is assigned to which. The keys and adjuster are because of the front of the equipment and permit the operation also with closed hood. Protection against impact sound and acoustic feedback offer the large shock absorbers of equipment feet.
RECORD PLAYER MT-6410
Operational principle half mechanism
Drive system belt drive
Engine direct current servo actuator
Speeds of 33 1/3, 45 U min.
Speed micro-adjustment ± 3%
Flutters WMRS 0.05%, DIN ± 0.14%
Rumpel weighted signal-to-noise ratio (DIN B) 65 railways
Range of adjustment of the tracking force 0 30 mN
Recommended tracking force 20 mN
Standard Tonabnehmersystern G-41 (audio Technica)
Mains connection 110/220 V, 50/60 cycles per second
Capacity 4 Watts
Dimensions (B x H x T) - hood geschlosssen 440 x 135 x 385 mm
Weight 4.6 kg
