Hi all,
I don't have a lot of experience with vintage hi-fi gear. Recently a friend and I have been cleaning up and trying to get running a Sansui G-9700, a Carver Receiver 2000, and this pair of Fisher President XP-18 speakers. The speakers are working well, the G-9700 works mostly (tuner needs attention, and it just started to drop the right channel), and the Carver likely needs the power supply rectifier diodes replaced (among other things?).
I have been quite impressed by their overall sound quality. Being as old as they are, I thought it might be time to reseal the surrounds. I purchased a product from "vintage-ar" on eBay based after reading on other forums that this product is used on AR cloth surrounds. It appears to be a butyl rubber in toluene solution.
While I was initially only planning on doing the woofers, I noticed that the upper mid range drivers have very pliable, almost limp, surrounds, almost as if they're not sealed. The lower mid range drivers' surrounds are noticeably stiffer.
Should I proceed with sealing the woofers only, or should the mids get some attention as well? I do notice that the mids seems to break up a bit with high intensity music. I was thinking that maybe more surround stiffness would help it cope.
I'm driving these with an Adcom GFA-545-ii/GFP-565 amp/pre-amp. I put my ADS L710s on this same stack with no similar break up that I could hear on the same track. It may be that it just how the Presidents are, and I should just leave them as is and enjoy.
Here's a few images of the Presidents.
Thanks for your advice.
