Fisher President Series XP-18 - surround resealing
Nice! What replacement tweeters did you use? Are the mids and woofers original drivers?
The woofers and midrange drivers in both sets are stock (original) unmolested , I was the first one into them.
Whatever dope Fisher used to seal the surrounds was still nice and pliable ,no need for re-doped so far.
As for the old Temple capacitors, well, they still passed sound to the drivers (most likely not to accurately, but....) so I left them in.
Bill Hecht 'Fried Egg' Dome Tweeter's are 16 ohm speakers, where do you find a new 16 ohm tweeter for replacement?
On my set of XP 15's the tweeters still worked (just barley, very low output) what I did for sh_ts and giggles (to get an idea of what they should sound like) was wire an old Motorola piezo (the smoother sounding ones) to the back terminals and set it on top the speakers. They have a frequency response from 4 kHz. - 27 kHz., 94 dB SPL and don't require a crossover, ended up sounding so good I've left them like that.
Been kicking around the idea of using a nice 8 ohm silk dome tweeter in place of the fried egg tweeter (in the speakers baffle) and another 8 ohm tweeter wired in series (inside the cabinet or maybe mounted facing out the back) to come up with 16 ohms.
And give them a proper re-cap, but it's not on top of the to-do list, maybe someday.
set-up from a few years past (sorry the pics a little dark and grainy, old Iphone , best shot I got)
Caps installed! Who needs a bunch of 50 year old electrolytics?
At first listen, I think the sound is more defined, higher clarity. Is this possible?
Well, the best way to test would have been to do only one speaker, then compare the two. But clarity is usually associated with mids and highs, and I would expect those to improve after replacing the caps.
Agreed, I did do a quick function check before moving on to speaker 2, but was more excited about completion that I didn't take the time. I have a pair of 43 year old ADS L710s that may be due next.
