Fisher rs 2010 bulbs
therringfxrp
Does anyone know what bulbs are typically used in the Fisher rs2010? I need three bulbs, non of them have any markings on them, don't want to kill anything with the wrong replacement bulb
Do you have a manual for it? Sometimes it will tell you in there. I didn't see one listed on Hifiengine.
You could test the voltage going to the bulbs and do an ebay search from there.
Since the question is specific to one particular model of Fisher equipment, thread is moved to the Fisher Forum.
Wedge Base like an automotive dash bulb #168 or 194? I think they are 8V 250ma or so. I went to the Auto store and temporarily used #194 bulbs in my RS-2003(should be the same bulbs as the RS 2010).
AK'er DGWOJO is the lamp guy. Check with him.
Larry
I picked up bulbs from the auto parts store, 14v 4.3watt.
They aren't as bright as the one remaining bulb that works, so I'm changing all 4...
They won't be. You're only pushing 8v thru a 14V lamp. But UNTIL you get the correct bulbs, they should work ok.
But I'd get the right bulbs asap.
Larry
