2d -- Your continued work is again superb!
If I may however, the schematic did you a disservice in its depiction of R124 and R125. While the schematic shows these resistors connected to the cathode terminals of the output tubes, in theory, and in the original build, they were in fact (and should be) connected directly to ground -- as they were (and still are) in my unit as well.
Now ultimately, if you install jumpers to ground out each cathode after completing the adjustment process, then it does not matter if you connect the resistors this way. But if you allow your cathode terminals to float on the new 10 ohm resistors installed during normal operation (which I do), then having R124 and R125 connected directly to the cathode terminals in this way negates the benefits of letting the cathodes float in the first place.
It's not an earth shaking concern, but from a technical point of view, the original build was correct, and the schematic is wrong, which is why the build of the unit did not match it.
I just wanted to let you know now, so you could reverse the work as you might deem necessary.
You will clearly have a super X-202 when you're finished. Good luck with it!
Dave
