Remove the ribbon cable from both the Dolby board AND the push switch board. The jumpers are all installed on the push switch board in the indicated holes formerly used by the ribbon cable. When you are done with this bypass, the Dolby board is completely disconnected. You can just clip off the loose yellow and black wires. You don't have to install it at all except without it, there will be open holes in the face plate.
He used red and blue to indicate the left and right channels continuing the Sansui format for the gray wires and blue signal wires. The white wire in each of shielded signal wires, is the wire carrying the signal. They go to pins one and two. Blue to one and Gray (red) to two. The other mesh wire is the ground. You will need to extend the ground wires to reach the indicated ground point on the push switch board.
Pete, et al,
Thank you for the clarification about disconnecting the ribbon cable from both the switch board and the Dolby board to effect the bypass as mentioned. Also yes about the blue / gray(red) relocation and the braided wire as the ground.
Is there a good thread to research/read on doing a Dolby Board repining? I’ve looked but yet to locate that
Also pondering the new Dolby boards available and moving components over to that as a fix
I’m weighing options about best solution
What time I have is limited to weekends due to work.
This 9090DB is unmolested as best as can tell and is worth the effort for sure.
The Rec-1 & Rec-2 switch positions & Rec Cal Tone & Meter buttons do not create the test tone
Audio (both channels present) is very faint. I’ve cleaned switches and buttons over and again.
I’ve been reading what I can find on the available solutions to these issues but have not been able to improve the situation past the symptoms listed above.
Advice is appreciated – I’m something of a newbie but have experience.
Progress on this 9090DB is stuck I think until one of the three options (re-repin, bypass or new Dolby board) is implemented.
Thanks Folks!
