pioneervato
Lunatic Member
I bought my Zerostat gun back when I was in college around 1977 or 78. I'm not sure when there first became available but I have the "white" Zerostat with the blue lettering on it.
Well anyway I had used it for several years and then stopped using it because the trigger mechanism seemed to stop working correctly like I remember it working. It has survived countless moves since my college years and so I today I decided to give it a look and see if it was something I could fix.
Luckily, the plastic housing on this model just snaps together and so taking it apart was pretty easy and was surprised as to its simplicity and minimal parts. I removed the small nut at the bottom end of piezoelectric thingamajig and with a 5/64" hex key I backed off the the small threaded set screw and was able to remove the thingamajig from inside the solid metal frame but I found nothing to indicate any problems.
And so I figured that maybe the setscrew had backed out some over the years when I was using it and so after realigning the thingamajig back into its metal frame and making sure the trigger pin fell into its proper place I slightly snugged up the set screw with the allen wrench, reinstalled and snugged up the small nut, snapped the housing back together and "BINGO", she works just like I remembered. Now when I pull the trigger I get, what feels to me, the resistance I remembered and the clicking of the trigger.
So if you have one of the older white ones like I do and have experienced a similar problem as I did then it might be an easy fix for you as well.
If you have never seen one in the nude before well here she is.
