audiopersyn
Member
Here are some more pictures of the process of opening a red Zerostat 3.
well here's a simple idea get a Neon test lamp or the test lamp that came with your Zero Stat and try your SLOW method and a fast method and see when the bulb lights up. if it lights up it's working PERIOD
Do as you like but on mine if I pull the trigger slowly enough to not CLICK the bulb never lights. If I pull it at about the speed the clicks start the bulb lights right at the moment of the CLICK.
I might be doing it completely work BUT then again after using it my Records sound statice free and I have watched dust fall off the charged vinyl as I use it.
YMMV
A click, or the lighting of the neon bulb, means that the ionic field has just discharged, and must be recharged through more trigger motion. The click or light is simply a test of field generation capability. Proper operation should result in a gentle hissing as the trigger is squeezed or released, which means that the field is charged up and ions are streaming out the pointed metal tip, one polarity as squeezed, and the opposite polarity as released.
Clicking means that the break down voltage has been reached because of charge being raised faster than ion expulsion can discharge it, resulting in an internal arc, discharging the field below what is necessary for ion stream expulsion.
Enjoy,
Rich P
Here is a link to a picture of the instructions from the zerstat back in the day when it was sold by discwasher...
http://db.audioasylum.com/cgi/m.mpl?forum=vinyl&n=744245&highlight=audiophiles
Also says to avoid the click.
terry
But are you sure it is working? Just the feel of the trigger may not indicate that it is doing its job right. Test it to be sure: try pointing it straight at your groin or stuck-out tongue, and then slowly pull...
That there just made my day . . . thanks, ARKAY:thmbsp:
You're most welcome. Reading that something I wrote just made someone's day just made my day! :yes: :thmbsp:
Wet your lips and bring the zerostat within about an 1/2 inch. Slowly squeeze the trigger. If it is working, you will feel a gentle breeze on your lips, when squeezing and releasing.Rich,
I used a voltage detector to determine field generation capability & it was positive. I don't seem to be getting the "gentle hissing" you mentioned (I do remember this use to be the case). Any theories as to why I'm not getting the "hiss"?
An internal click is a spark from the connection point of the wire to the crystal rod, to the metal frame that holds it.
Enjoy,
Rich P
I had one back when, thot it was red but mebbe not. It died and when I disassembled it I found the steel frame fractured so no reapirs here. I got another one in the early '90s and it still works.
BTW, it's advisable not to zap your records on a TT if it has "electronic" control systems. Avoid zapping your cartridge as well.
revisit
The white I bought in 1975 'clicks' pretty easily, the red almost never, and the Spiratone version is almost impossible to pull without clicking. I wonder what accounts for the variation?
