bzenic
I have this situation:
Right now I have only one STK-0050 in, the other one is removed because it was bad.
When I play some FM station in STEREO the sound is very low volume and intermittent. If I slowly turn the tuning knob the loud noise waves occur and then settle to the previos low volume. When I switch to MONO the sound volume increases and it is better in quality.
I guess this happens because the other channel preamp (the one without STK) is also included.
I was checking a bunch of transistors using ATLAS semiconductor tester but so far could not find a bad one, I still have not tested all of them.
Could it be that a bad capacitor causes these symptoms?
Where should I look and how to proceed?
